if ($scheme != "https") {
    rewrite ^ https://www.android-port.de$request_uri? permanent;
if (!-e $request_filename){
    rewrite ^(.*)$ /index.php break;
location /msd {
    auth_basic "MSD";
    auth_basic_user_file /pfad/.htpasswd;
location /tools {
    auth_basic "Tools";
    auth_basic_user_file /pfad/android-port.de/.htpasswd;
location /install {
    auth_basic "Installation";
location /pfad/android-port.de/ {
    try_files $uri $uri/ /pfad/android-port.de/index.php?$uri&$args;
    index index.php index.html;
location /pfad/android-port.de/internal_data/ {
    internal;
location /pfad/android-port.de/library/ {
    internal;
location ~ \.php$ {
    try_files $uri =404;
    fastcgi_pass    127.0.0.1:9000;
    fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
    include         fastcgi_params;
location ~* \.(jpg|jpeg|gif|png|css|js|ico|xml)$ {
    access_log        off; # deaktiviert access_log für diese Dateitypen
    log_not_found     off; # deaktiviert Meldungen im error_log
    add_header Pragma public;
    add_header Cache-Control “public”;
    try_files $uri @fallback;
    expires           30d;
gzip on;
gzip_proxied any;
gzip_types text/plain text/css application/json application/javascript application/x-javascript text/xml application/xml application/xml+rss text/javascript;
gzip_vary on;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
gzip_disable "MSIE [1-6]\.(?!.*SV1)";
pagespeed EnableFilters combine_css;
pagespeed EnableFilters collapse_whitespace;
pagespeed EnableFilters make_google_analytics_async;
pagespeed EnableFilters canonicalize_javascript_libraries;
pagespeed EnableFilters remove_comments;
pagespeed EnableFilters rewrite_images;
pagespeed EnableFilters move_css_above_scripts;
pagespeed EnableFilters move_css_to_head;
pagespeed EnableFilters outline_css;
pagespeed CssOutlineMinBytes 3000;
fastcgi_read_timeout 300;
autoindex off;location ~ \.php$ {
        fastcgi_pass unix:/var/run/php5-fpm.sock;
        fastcgi_index  index.php;
        fastcgi_send_timeout 180;
        fastcgi_connect_timeout 60;
        fastcgi_ignore_client_abort off;
        fastcgi_intercept_errors on;# Media: images, icons, video, audio, HTC
        location ~* \.(?:jpg|jpeg|gif|png|ico|gz|svg|svgz|mp4|ogg|ogv|webm|htc|woff)$ {
            expires 1M;
            access_log off;
            add_header Cache-Control "public";
# CSS and Javascript
        location ~* \.(?:css|js)$ {
            expires 1y;
            access_log off;
    }# Disable direct access of any *.php files in /wp_includes folder
location ~ ^/wp-includes/.+\.php$ {
   return 444;
# Disable direct access of any *.php in /wp_content folder
location ~ ^/wp-content/.+\.php$ {
   return 444;
# Disable direct access of any *.php in /plus folder
location ~ ^/plus/.+\.php$ {
   return 444;
# Disable direct access of any *.php in /wp-admin folder
location ~ ^/wp-admin/.+\.php$ {
   return 444;
}Wir verwenden essentielle Cookies, damit diese Website funktioniert, und optionale Cookies, um den Komfort bei der Nutzung zu verbessern.
