vFranky
- 17. Nov. 2013
Hallo Leute,
ich habe heute versucht ein etwas größeres vBulletin-Forum nach XenForo zu importieren. Es lief recht lange gut, bis ungefähr 80% und dann kam ein "Duplicate entry for Primary Key", der den Import abbrach. Hat jemand eine Ahnung was das sein könnte? Siehe unten.
Viele Grüße
Frank
Viele Grüße
Frank
Server Error
Mysqli statement execute error : Duplicate entry '442946' for key 'PRIMARY'
Zend_Db_Statement_Mysqli->_execute() in Zend/Db/Statement.php at line 297
Zend_Db_Statement->execute() in Zend/Db/Adapter/Abstract.php at line 479
Zend_Db_Adapter_Abstract->query() in Zend/Db/Adapter/Abstract.php at line 574
Zend_Db_Adapter_Abstract->insert() in XenForo/DataWriter.php at line 1638
XenForo_DataWriter->_insert() in XenForo/DataWriter.php at line 1627
XenForo_DataWriter->_save() in XenForo/DataWriter.php at line 1419
XenForo_DataWriter->save() in XenForo/Model/Import.php at line 617
XenForo_Model_Import->_importData() in XenForo/Model/Import.php at line 1750
XenForo_Model_Import->importPost() in XenForo/Importer/vBulletin.php at line 2651
XenForo_Importer_vBulletin->stepThreads() in XenForo/Importer/Abstract.php at line 97
XenForo_Importer_Abstract->runStep() in XenForo/ControllerAdmin/Import.php at line 189
XenForo_ControllerAdmin_Import->_runStep() in XenForo/ControllerAdmin/Import.php at line 137
XenForo_ControllerAdmin_Import->actionImport() in XenForo/FrontController.php at line 351
XenForo_FrontController->dispatch() in XenForo/FrontController.php at line 134
XenForo_FrontController->run() in /home/www/domains/test.taschenlampen-forum.de/admin.php at line 13
array(3) {
["url"] => string(58) "http://test.taschenlampen-forum.de/admin.php?import/import"
["_GET"] => array(1) {
["import/import"] => string(0) ""
["_POST"] => array(1) {
["_xfToken"] => string(8) "********"
