eichenkranz
- 3. Sep. 2014
Wie bekomme ich das hin das der Chat über dem Forum steht ....... geht das überhaubt ???
If you use [bd] Widget Framework:
If you DO NOT use [bd] Widget Framework:
- Upload contents of upload folder to forum root.
- Install new addon using addon-TaigaChat.xml.
- Set the permissions for all relevant user groups.
- Import widget_framework_taigachat_pro.xml from Appearance > Import Widgets - do NOT delete your existing widgets when prompted.
Then, go to Appearance > List Widgets and enable one of the two available Shoutbox types (Sidebar or Full width), and additionally the ‘Users in Chat’ widget if you desire.- Observe the settings in Home > Options > TaigaChat Pro, especially the top setting (‘Speed mode’) if shoutbox security matters.
- If you use XenPorta and wish to include TaigaChat in your portal, upload contents of xenporta/upload folder to your forum root, then in Home > Blocks > Install Block, install TaigaChat.xml, TaigaChatAlt.xml and TaigaChatOnline.xml.
- For sidebar: in the forum_list template, before or after (personal preference) <xen:include template="sidebar_online_users" /> add <xen:hook name="dark_taigachat" />
For full width above/below forum list: in the forum_list template, before or after (personal preference) <xen:if is="{$renderedNodes}"><xen:include template="node_list" /></xen:if> add <xen:hook name="dark_taigachat_alt" />- Observe the settings in Home > Options > TaigaChat Pro, especially the top setting (‘Speed mode’) if shoutbox security matters.
